Ways to relieve fuel pressure w/o turning the engine on? | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by twelvehundredbucks, Mar 27, 2010.
  1. twelvehundredbucks
    twelvehundredbucks New Member
    5
    Is there a way to do this? I have a 95 lx wagon. Thanks
  2. Setnev
    Setnev FEOA Member
    358
    168
    Phoenix, AZ
    Bleed it through the pressure release valve on the fuel rail. Just to be warned, you're gonna get fuel everywhere by doing it that way.
  3. Green91Goblin
    Green91Goblin New Member
    1,389
    Corinth, MS
    Correct me if I'm wrong, but why not start the car, and pull the plug on your inertia switch? Either that or find the fuse for your FP in the BJB and pull it? (FP = Fuel pump, BJB = Battery junction box)
  4. silverton
    silverton FEOA Member
    2,719
    288
    Seattle, WA
    if it cranks, knock the inertia switch so that it is popped up. it's in the rear passenger interior piece, should have a little accessy thingy back there. hit it with some sort of blunt object til it pops up, and then just crank away with the gas cap off. shouldn't take too long to bleed the pressure.
  5. juggalo
    juggalo New Member
    6,096
    9
    Tacoma, WA
    instead of hittin it, u can take it off the strut tower and shake it
  6. silverton
    2,719
    288
    Seattle, WA
    hitting it is easier.
