w00t! 36+ mpg wagon! | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by LowriderS10, Feb 4, 2010.
  1. NorthCoastEscort
    NorthCoastEscort New Member
    25
    I bought my LX for a commuter. I do mostly two lane hwy driving so no express ways. I have yet to get it on the road but I expect to get 40+ consistanly. I also hyper mile and I know in my current aspire it can change my milage from 32 mpg to 36 just by the driving style. I still have to get it put together but I will keep you posted. I would like to se section on to share MPG tips.
  2. denisond3
    10,237
    2,890
    The PCM makes decisions based on inputs from sensors - and all of the sensors (except the CPS) probably have some manufacturing tolerance to their output. I wonder how those minor differences affect the MPG? Your driving style, the terrain, the number of times you have to use the brakes or stop certainly make a big difference. And we all know about the beneficial effects of a recent 3 angle valve job, new plugs & wires, clean air filter and throttle body, fully inflated tires, etc.
    It might be nice if you could fiddle around with the sensors, choosing ones that cause the engine to run the best or most consistently. I guess thats why megasquirters exist.
    There was a poster who reported as high as 47 mpg. He talked about having fender skirts over the rear wheels, and tried an air scoop under the front bumper, and doing 'pulse & glide' driving (whatever that amounts to).
    I know that if you want best speed/performance in an airplane you close up as many of the seams as you can - such as using tape to cover up the gaps around the doors, windows, etc.
  3. Intuit
    Intuit FEOA Member
    7,593
    949
    Southwest Ohio
    If all you're driving is small... make that tiny trips, then your mileage should be HORRIBLE.
  4. Intuit
    Intuit FEOA Member
    7,593
    949
    Southwest Ohio
    It seems that would decrease mileage. The only purpose for low-to-the-ground air scoops is to increase vehicle down-force at high speeds. This helps keep air from getting underneath (just think speed-boat crashes) allowing for higher top-speeds. Increased down-force is for sticking to the road, allowing for higher speed cornering.
    Well, maybe not. Suppose it's all in how it's designed. If it keeps air out of the radiator then I suppose it could make a minute difference in drag for daily-driver vehicles.
  5. Setnev
    Setnev FEOA Member
    358
    168
    Phoenix, AZ
    Seriously????
    My post was an /exageration
    Please! You think Scottsdale PD is gonna let me get away driving that fast?
  6. the1nicko
    the1nicko New Member
    230
    I am only getting 22mpg with no CEL, brand new air filter, coil, plugs, wires, o2 sensor, fuel filter, and no vacuum leaks. I am not sure what to do.
  7. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    ^^try cleaning the maf, check the resistance of the ect, and changing the fluids.
  8. the1nicko
    230
    Like the tranny fluid and filter? I just changed the head on it with a reman, so the oil and coolant is fresh. I also got 13" wheels on her. Could a bad IAC cause bad gas mileage? I am also not sure if this could effect gas mileage but my temp gauge doesnt work, I just changed all the coolant temp sensors and checked the grounds, I am not sure how to fix that either.
  9. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    if ur temp gauge isn't workin, of corse ur gonna get 22mpg cuz the ecu isn't comin out of warm up mode.
  10. the1nicko
    230
    how do i make it work?
    Does the temp switch wire go to the computer or just to the gauge? Could my gauge just be bad?
  11. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    using a volt/ohmmeter with jumperwires, u need to make sure there's voltage goin to the sensors on the thermostat housing and the resistance of the sensors r at their specs. u should also check the thermostat by puttin it in boiling water with a thermometer so u can verify at what temp it opens or even if it does open.
  12. the1nicko
    230
    Well the tstat is also brand new. Does the temp sender actually go to the computer or does the wire just go to the gauge? Is it possible my gauge could be bad?
  13. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    i believe the temp sender goes to the ecu then the gauge. i don't think gauges go bad.
  14. madmatt2024
    madmatt2024 FEOA Member
    9,924
    437
    383
    Upstate N.Y.
    There are two temp sensors (three in some cases). One is for the gauge and one is for the computer. It is possible that your gauge is just bad. The best thing you can do is make sure the metal piece the sensors are screwed into is grounded well. If in doubt you can run a wire directly from where it bolts to the engine to the negative battery terminal or a ground point on the frame.
    Make sure your plugs are gaped properly and also look for a dragging brake. Both can kill your mileage.
  15. the1nicko
    230
    hmm ive been looking through my haynes book and can only find a pin that goes to the coolant temp sensor. In my all data it says to check the voltage at the cluster and if there is no voltage to replace the gauge.
  16. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    what matt said.
  17. madmatt2024
    9,924
    437
    383
    Upstate N.Y.
    Another way to check the gauge is to unplug the single wire temp sensor and attach the wire to ground. If you do this the gauge should go all the way to hot.
  18. the1nicko
    230
    ok sweet thanks matt. I do have the 3 sensors. What happened was I was changing my starter and bumped the coolant temp sensor and it broke. So I changed it. After that my gauge stopped working. So I changed the temp sending unit, but still didnt work. I checked the sensor grounds and they are good, I am going to try what you said and see if the gauge is working.
    going back to the gas mileage I changed the plugs but I dont remember if I gapped them correctly, thinking back I think I installed them and then remembered I forgot to check the gap and just left them, so I am going to swap them out friday.
  19. FordMan59
    FordMan59 FEOA Member
    4,556
    446
    333
    Russellville, Kentucky
    If it's just the guage it wouldn't affect mileage, but if the car is not coming up to the correct operating temperature or the sensor that sends the signal to the ECU is bad, telling the ECU that the car is only running at 100* then the car is running in open loop all the time dumping excess fuel to the engine.
  20. yournamehere
    yournamehere New Member
    244
    Haverhill, MA
    Now that's it's mentioned, my temp gauge only goes up about 3/8" past the cold line.
    My heat has been fine and the car seemed to run fine so I just left it as is.
    Is that the normal spot for the needle when the car is up to temp? If not, what would it be? just a tstat i assume?
