VSS replaced by mechanic I got questions | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by Gabriel Panoussi, Jul 23, 2016.
  1. Gabriel Panoussi
    Gabriel Panoussi My approval ratings have droped.
    162
    34
    88
    Flint, MI
    So after an ordeal at the mechanic my VSS was replaced. Mechanic first said 50 then broke hold down bolt said he could not do it for 50 more like 200 I protested then said he cant do it all after spiting the sensor. Was told trans needs to be taken apart then pushed out from inside. Finally after much complaints they offered to make it right by buying a used tranny and installing for the original 50. After all that mechanic finally got it out by grinding and driving a lag screw to pull it out. Poor guy I knew it was a pain. Ended up doing for 50 as agreed.
    So everything is fine except I don't see the speed cable coming out the top. Speedometer works though. When I asked mechanic said it did not have one and was electronically controlled. The car is a 97 Ford Escort Automatic Sedan. So do I have a cable that goes on the top of the vss or not is my question.
  2. pextor
    pextor Moderator Staff Member
    6,011
    842
    Lancaster, pa
    it is electronic. there are only two wires coming out of the sensor.
    Gabriel Panoussi and copcarguy like this.
  3. copcarguy
    copcarguy FEOA Member
    1,995
    858
    263
    Northeast PA
    No cable.
    Gabriel Panoussi likes this.
  4. Intuit
    Intuit FEOA Member
    7,559
    938
    Southwest Ohio
    Tip the mechanic... or at least send'em a pizza. I'll bet there were more curse words flying around that shop than we'd care to know. Those speed sensors have been known to be a real PITA to remove.
  5. copcarguy
    1,995
    858
    263
    Northeast PA
    It's amazing what having a pizza or two delivered now & then does to speed up your stay lol.
  6. Gabriel Panoussi
    162
    34
    88
    Flint, MI
    Thanks Guys I got thrown off by a blue cable that looked like it was routed on the vss bracket which it thought went to the vss. When I got it back did not see the blue cable. Was told it was wire harness that was moved?
    I did feel bad for the guys so I showed up with a sack of beers when I picked her up.
  7. Intuit
    Intuit FEOA Member
    7,559
    938
    Southwest Ohio
    Beer? Glad my car wasn't next to get worked on LoL.... ;)
