1 - 9 of 9 Posts
Discussion Starter #1
Hi,
I have an LX-E (1.8L Mazda) with an automatic trans.
The car is VERY slow under acceleration, unless I shift into low. Then is fast until I run out of gear and have to shift into drive.
It feels like the car is either not starting in 1st, or is staring in first and quickly upshifting before i get any good acceleration.
If i start in low and shift to drive, it seams like the car is shifting straight from 1 to 3.
I think that it is a problem with the kickdown, but the kickdown seems to be working properly until the cable enters into the trans (cannot see it after that). I replaced the speed sensor twice, and the speedo does work.
I have started to run out of ideas, and am looking for some help... Thanks!
AJRacing_Tony said:
Hi,
Did you change out your spark plugs and check fuel injectors?
EscorGo said:
Not sure what spark plugs and injectors have to do with it (?)
You might start by changing the fluid and trans filter. I'm no trans expert and I don't play one on TV
Loss of power...
go take out one of your spark plugs and tell me the difference ;)
Loss of power...
Read the post again. He is talking about a shift problem.
he's talking about what he thinks is a shifting problem but isnt sure.. so i wouldnt count anything out at this time.
if the plugs are heavily worn, the large plug gap can cause a huge loss of power.
thank you.
anything is possible and i know that spark plugs COULD cause a problem as ive seen it personally on more than one occasion and fixed a few cars that ONLY needed spark plugs with the loss of power.
And Escorgo I know i have a low post count but if i DO post i have some knowledge behind what im talking about not like you who thinks he knows it all ;)
1 - 9 of 9 Posts
