Very little dash light | Ford Escort Owners Association (FEOA)
Discussion in 'Interior Modifications' started by EscortingShagWagon, Feb 10, 2018.
  1. EscortingShagWagon
    EscortingShagWagon FEOA Member
    103
    13
    18
    Assuming most of my cluster lights are burned out, how diffacult of a job isn't to eplace the bulbs? Also what doninreplace them with? Are they just like 168's?
  2. pextor
    pextor Moderator Staff Member
    5,961
    811
    Lancaster, pa
    It's not hard to do at all. I'll be doing it to my 97 as soon as the weather warms up a little.
  3. cwol97401
    cwol97401 FEOA Member
    701
    221
    193
    Midwestern Oregon
    The dash lights are #194. I can't remember if there's 5 or 6 bulbs. If you do a quick search, there are several posts on our forum describing how to remove and reinstall the instrument cluster.
    Tapatalk
  4. EscortingShagWagon
    103
    13
    18
    Thank you everyone!
  5. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,434
    1,131
    Vancouver Island, Canada
    If you have the instrument panel out for some reason without enough new bulbs, you can swap the partly silvered over dim bulbs with the ones for the idiot lights, which will presumably be very little used.
  6. FordMan59
    FordMan59 FEOA Member
    4,552
    442
    333
    Russellville, Kentucky
    The idiot lights have a smaller base. I replaced the ones in my '97 wagon with LED's the cluster lights are T10 and the idiot lights are T5. OP, if you're not in a hurry to change them you can get LED's on eBay out of China for around 10/$1-$2. They seem to be doing fine in my wagon. If you replace them with LED's be sure to check the light operation before you reinstall the dash. If the light doesn't burn take it out, turn it 180*, reinsert it and it should work. Here's what I used for cluster lights. https://www.ebay.com/itm/10X-T10-W5...ash=item4d41a0b9ff:g:4m8AAOSwZ8ZW9iWS&vxp=mtr Here's what I used in the idiot lights https://www.ebay.com/itm/10pcs-T5-D...ash=item466ef7b8fe:g:GWkAAOSwhpZZ-SlP&vxp=mtr
  7. cwol97401
    701
    221
    193
    Midwestern Oregon
    I believe on the second gen cars the bulbs are all the same size, not like our third gens
    Tapatalk
  8. zzyzzx
    15,091
    1,198
    Yeah, and I've replace bulbs without having to remove the dash too.
  9. FordMan59
    4,552
    442
    333
    Don't know what I was thinking. I didn't have to remove the dash. I just removed the cluster so it should have read check light operation before reinstalling the cluster.
  10. Itchigo
    Itchigo FEOA Member
    375
    117
    193
    Don't even have to take it out. Take the glass off and do it through the front.
