1 - 4 of 4 Posts
It's an '87. If the engine is original then it will use hydraulic. Ford switched to hydraulic roller lifters for the 88.5-90 model years. If the head was replaced, and the casting is E8 or E9, then you've probably got a roller head. The easiest way to check is to take a rocker arm off, and pull a lifter. If it's flat on the bottom it's hydraulic; if it has a wheel, it's roller.
1 - 4 of 4 Posts
