Good Evening: i was playing with the TPS adjustment (it doesn´t work because the ECU reset the value every time you turn off the car) and i take out the hose from the valve cover to the check valve and to the intake hose and found that i have vacuum on the valve cover, i really don´t know why, i put my finger on this port and it suck it, if i kee my finger the car valve cover start to make some weird noise.
can you explain this to me because i was thinking that i have something wrong with my PCV system.
i think on december i put a oil separator between the PCV valve and the Intake manifold, and found a problem with the check valve from the valve cover to the intake manifold so i change it and keep the direction as the manual says "arrow, flow from intake to valve cover"
i really don´t know what´s going on, please any advise
