For Sale - US Touring CAR Ford EGT Part out thread | Ford Escort Owners Association (FEOA)
For Sale US Touring CAR Ford EGT Part out thread
Discussion in 'US Classifieds' started by piercemotorsports, Mar 30, 2013.
  1. piercemotorsports
    piercemotorsports FEOA Member
    629
    5
    268
    Hey guys---here's the partout thread for the car---you can find the build thread In the autocross/roadrace section for specifics. There's probably parts that I'm forgetting and if you need something specifically, let me know and I'll look for it-thanks!
    [​IMG]
    [​IMG]
    New listings for 3-31-13
    91 Ford Escort GT shell---acid dipped, seamwelded, primered and painted white---full FIA Touring car cage---$3000 plus shipping
    We have 4 team dynamics black wheels 17x9" with Khumo 245/40/17 v710 mounted up. Tires are Dot slicks and have 6 15 minute sessions on them. Wheels are nearly $200 each with shipping and the tires are over $200 each mounted and they have plenty of tread left...$500 for everything plus some shipping!
    GTR engine-jdm engine, has been run for a few 20 minute sessions in "blacky" then driven on road for about 200 mi or so before acquired for the project. Leak down/ compression were great and it ran a few weeks ago before the fuel system was sold-will need fuel rail. Iinjectors/fuel rail is there, but rail was damaged when lines were removed---I may have gtx fuel rail actually---any rate $1500 plus some shipping.
    Front spindles with brand new hubs ($200 plus labor)---the brake caliper mounting holes have been drilled out for the wilwood brake kit, but would still accept stock calipers with a little work---$100 for the pair shipped.
    Rear brakes---We've got the new hubs/rotor's/calipers/Hawk race brakepads and braided lines for $300 shipped---(we paid like-rotors $150, new calipers $200, hawk pads $120, brake lines-$120 plus the new rear hubs...).
    Rear crossmember---blasted/seam welded/primed and painted---just cleaned up and has a modified swaybar perch to accept different bars (2 bolt bushing upgrade) $100 plus shipping.
    Front crossmember---blasted/primed/painted and comes with an upgraded ZX2 larger front bar (modified mounting points) with new bushings---$150 plus shipping.
    Front steering rack (power) with new inner/outer tierods---nothing fancy, just rebuilt to stock with new bushings---$100 plus shipping.
    The doors are fiberglass and in the pics you can see the drivers door has been cut for the rollcage---however the top has been left in so a carbon panel could easily be used to cover everything up---the passenger door is in tact---They're painted white and in good shape. They weigh about 8lbs each gutted (the stock ones are over 80lbs each!)---they sell on my site for $900 shipped and we sell a couple sets a year all around the planet. These I'll let go for $500 for the pair plus shipping---they'll go truck freight and be under $200 for shipping.
    The rear hatch is carbon and has been painted white---all the holes have been filled for the wing, but of course could be re-drilled. Let's say $300 plus shipping for it.
    The widebody kit /arch's are fiberglass and have been shaped to fit the EGT---they blend into the fiberglass lower sideskirts nicely---They'll bolt onto the front fenders and the quarters in the back---we have black fender molding from the Porsche 930 turbo that goes with them so they can bolt on and be replaced easily. The 4 arch's and 2 sideskirts are all painted white as well---they'll allow for a 17x9" rim with a 275/45/17 tire---plenty of rubber/clearance! $500 shipped here in the US. If the person that buys the kit also wants the front fenders they are free for him---he just needs to pay for the shipping...(fenders are easily trimmed/gotten from a local distributor and might not be worth shipping).
    The lexan windows---2 quarters and the rear---they're all cut/fit and save about 35lbs of weight. The quarters are painted nicely---the rear will need be re-painted touched up. They are all new and scratch free/ready to be installed---$250 for the set plus some shipping or $200 for the quarters and $100 for the rear---plus shipping...
    The front bumper and transition---it's a BMW E46 M3 bumper with a DTM front splitter---I hate myself for grafting it in there, but it was inexpensive, easily gotten, like 6lbs and poly so it can take abuse---and the front splitter was already designed (there's a million of them...) and functional---it ended up being the perfect width...I think I've got $500+invested in them---if someone wants it with the aluminum transitions into the widebody arch's then $300 plus shipping...
    UPDATE/New stuff for 3-20-13
    GTX Ecu-$100 shipped!
    Rebuilt starter-$50 shipped!
    Two stock escort wheels---$50 plus shipping.
    Tilton Pedal box with MC set up for Escort---has lower aluminum mounting plate perfectly fit to escort floor board. Comes with brakes lines to bulkhead/clutch line-$600 plus shipping
    Remote mounted Steering column---quick release, DTM flatbottom steering wheel, 6" collapse built into column---comes with linkage/ujoints to adapt straight to escort/protege steering rack---$300 plus shipping
    MSD Blaster coil/anti Vibration-$25 plus shipping
    Aeromotive Fuel Pressure regulator with gauge-$60 plus shipping
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    escortponyjunkie likes this.
  2. yeaman5
    yeaman5 FEOA Member
    78
    16
    Danville, Va
    do you have a transmission?
  3. piercemotorsports
    629
    5
    268
    Sorry it sold pdq..
  4. slowscort
    slowscort New Member
    8
    front lip? grill? forsale?
  5. piercemotorsports
    629
    5
    268
    Absolutely---the grill's been painted white now---say $35 shipped, and the front lip (bottom DTM on the bumper) say $200 shipped---If you want the whole bumper, I'll do $350 shipped ($300 local pickup...)
  6. slowscort
    8
    where ya located? :idea:
  7. piercemotorsports
    629
    5
    268
    Torrance-California---LA basically...
  8. piercemotorsports
    629
    5
    268
    Motors gone/just sold!
  9. pnmred
    pnmred FEOA Member
    306
    27
    178
    MIDWEST
    getting out of the escort biz?
  10. piercemotorsports
    629
    5
    268
    Not at all---I think we've got more products for them than anyone in the world at this point---we did just add a front/rear chromoly one piece strutbrace---really nice stuff, I'll tigged/moly with dimpled plates...I think next we're going to be developing the "frog arms"/fender brace deals---the folks in Australia are looking for them...
  11. pnmred
    pnmred FEOA Member
    306
    27
    178
    MIDWEST
    Just curious because I also believe you guys have the most extensive inventory of parts for escorts at least structural, so the thought of you guys throwing in the towel did make me sad. Honestly if there is anything that needs tackling on these damned escorts it's the transmission issue.
  12. yeaman5
    yeaman5 FEOA Member
    78
    16
    Danville, Va
    shift linkage?
  13. pnmred
    pnmred FEOA Member
    306
    27
    178
    MIDWEST
    just the fact that when it comes to making power and putting it to the ground, your options are poor
  14. 95gtescort
    95gtescort FEOA Member
    18
    31
    Anaheim, Ca.
    Do you have a factory GT front bumper for a 2nd gen sitting around that I could buy off of you? I'm in Anaheim so I could easily pick it up.
  15. WorldHazard
    WorldHazard FEOA Member
    17
    63
    PNW
    pm'd ya. interested in the msd coil
  16. escortponyjunkie
    escortponyjunkie FEOA Donator
    262
    31
    58
    illinois
    rear spindles for disc break conversion?
  17. RcCarRacer1992
    RcCarRacer1992 FEOA Member
    491
    10
    168
    Just so everyone knows, it is a year and a half old. or damn near it.
  18. escortponyjunkie
    262
    31
    58
    illinois
    Haha.. I just noticed the dates.. oopsie.
    Sent from my LGL55C using Tapatalk 2
  19. piercemotorsports
    629
    5
    268
    Hey guys---had my nose to the grindstone for the last 2 years working on all sorts of projects---I believe we still have a shell left on this---still have the 17x9 4x100 team dynamics, wide body kit/arch's, other misc stuff we'd like to get rid of before the new year!!
  20. southerncaddy
    southerncaddy FEOA Member
    82
    108
    wouldnt happen to have a good 5 spd shifter assembly and linkages would you
