The clutch safety switch will be located on the clutch pedal itself. Look at the pedal under the dash, and where it mounts. You'll notice the cable adjust quadrant, and there should be the safety switch in that area.
If it's not there, then it might've been removed or disabled. They all came with one then, but I have seen them be removed, basically telling the computer the clutch pedal is always pressed in.
