good afternoon:
since yesterday i have this weird problem, my car are overheating but only when i rise the volume of my stereo, i only have 1 Sony explode amp (150 watts x 2 (2 ohm) and 300 watts x 1 (4 ohm) rms, 4 speaker (2 front and 2 rear), one 10" subwoofer Infinity 300 watts rms. i have 2 year with this stereo config, since then the temp gage move weird but right know it moves worst.
i can hear the high speed fan and the temp start to decrease but only when the stereo are in a normal volume, if i increase the volume (too much bass) the gage rise suddenly.
i have no leaks, good colant level (radiator and tank), and when the needle start to pass the middle i turn on the AC and the low speed fan put the needle down (1/4) then i turn off.
ah, yesterday when i stop the car in my house the temp was good, but when i close the gate suddlenly the tank or reservoir start to make noise, so i heard like boiling but no bubbles. i reffil to max the coolant, i wait like 2 hours to open the radiator and the level was ok, level in the neck and the level in the reservoir was change, lower, between max and min.
what can it be?
1- bad alternator, no juicy power to run the high speed fan with the stereo on?
2- Bad stereo ground?
3- bad high speed relay fan (CCRM)? well the fan move ok
4- bad thermostat, i've notice in the morning (like 50 F) the car don't warmup pass 10 - 20 min then the gage start to move.
please any advise
what can it be?
please any advise
