Unable to access Rockauto site | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by Joey_Twowagons, Jun 16, 2019.
  1. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,080
    914
    363
    Vancouver Island, Canada
    Hi All, for the last few days I cannot get Rockauto on the computer. On Mozzilla I get the "The connection has timed out" after a few minutes. On Internet Explorer the page just cycles back to the search page.
    Other sites are working normally.
    I've run the Windows Defender and Norton anti virus programs which find nothing wrong.
    Anyone else have this problem? Any ideas of what I can try?
  2. Gamer92
    Gamer92 FEOA Donator
    3,424
    974
    263
    Southern Indiana
    Seems to work fine for me. I’m using safari on iOS
    Maybe try another browser?
    I prefer chrome on windows
  3. 93scortluv
    93scortluv Administrator Staff Member
    3,934
    150
    315
    Rhode Island
    working out here in RI.
  4. Joey_Twowagons
    2,080
    914
    363
    Well I have tried two browsers, and until now I've had no problems. I guess it might be a local problem.
  5. Gamer92
    3,424
    974
    263
    Southern Indiana
    Does it work on another computer or phone?
  6. Joey_Twowagons
    2,080
    914
    363
    I just tried Duck Duck Go, and still it is not working.
    The server at www.rockauto.com is taking too long to respond."
  7. Joey_Twowagons
    2,080
    914
    363
    Well the wife's out of town, so I guess I'll try to hack into her computer tomorrow as it's now bedtime for mechanics.
  8. Gamer92
    3,424
    974
    263
    Southern Indiana
    Any updates?
  9. Joey_Twowagons
    2,080
    914
    363
    Yes... the update is, I still can't connect. I tried the wife's computer and had similar lack of success.
    The Google search shows the typical myriad results, but when I "click" on it, there is about a thirty second delay until the dreaded "Timed Out" page comes up.
    I am planning to buy some parts for a neighbour's car to repair, I might try at his place.
  10. Bullethead104
    Bullethead104 FEOA Member
    213
    60
    178
    It's up in Mass.
  11. Bullethead104
    213
    60
    178
    Solar Flares maybe ???
  12. Joey_Twowagons
    2,080
    914
    363
    I tried from a friend's place five miles away, it worked there.
  13. Gamer92
    3,424
    974
    263
    Southern Indiana
    Were you able to try on your wife’s computer?
  14. Joey_Twowagons
    2,080
    914
    363
    Yes, I used the spouse's computer with the same results. I also plugged the computer directly into the modem instead of using the wifi or whatever it is, in the house.
    Still no luck, Rockauto comes up as:
    It does take about half a minute to get that message, and the little circular thing at the tab header spins around. So it definitely is trying.
  15. Gamer92
    3,424
    974
    263
    Southern Indiana
    Maybe your isp blocked it?
    Could anyone you know bring a computer over to your house? Could be something on your computers blocking it.
    Do you have a smartphone you could try?
  16. Joey_Twowagons
    2,080
    914
    363
    I tried an IPAD, and it says "Safari could not open the page because the server stopped responding".
    How can I find out if it is blocked by an ISP? I think this less likely because the messages always say "Timed Out" rather than blocked.
  17. Gamer92
    3,424
    974
    263
    Southern Indiana
    Call them I guess.
    It could also be your wireless router. Is your network secure?
  18. Gamer92
    3,424
    974
    263
    Southern Indiana
    @Intuit
    Do you have any ideas on this?
  19. Intuit
    Intuit FEOA Member
    7,481
    889
    313
    Southwest Ohio
    Hi Gamer!
    Looks like you're already on the right track.
    Site is accessible from other spots, but not at home. It would be incredibly odd if that really is the only site that is affected. I'll bet there are others. Assuming that it really is just that site, it's either the router or the ISP.
    It could also be the particular server IP that your DNS (computer phone book) is resolving to. If we all ping Google.Com, we're all going to resolve to different IP addresses; depending on region. RockAuto might be setup the same way.
    @Joey_Twowagons - Do you have any sort of web filtering service? (blocking porn sites for instance) Try typing in "https://www.rockauto.com/". Still an issue? Open your Start Menu, type "Command Prompt" and in the black window type "IPConfig /ALL". In the output, you'll have the DNS servers listed. It is typically set to that of your router's IP... typically equal to the Gateway address. Type "ping www.rockauto.com" and you'll get an IPv4 address. Try plugging in that IP address in place of the friendly name... "https://198.27.61.99/" for example.
  20. Joey_Twowagons
    2,080
    914
    363
    I phoned up the provider and the tech support is working on it, they phoned me back after doing a bunch of magic stuff without success, and will phone me again after doing some more.
    I did try typing in "https://rockauto.com/" and "https://198.27.61.99/ " with the same lack of success as ever.
    Hopefully the tech support will come through.
