I am thrilled with my KVR pads, KVR cross-drilled, cad-plated rotors, and TechnaFit lines. The pedal pressure required is greatly reduced and the cold and/or wet performance is everything that I had hoped it would be. In my opinion, many of us don´t exceed the performance of a properly prepared stock system. A big brake kit, if well-designed, would improve braking performance, but, for me, the more tame route is the way to go.
There are many, many options and brands available that, would work just as well as what I chose, but through my research, the KVR/TechnaFit option got the nod. For actual comparison, I can only report that they perform better than both my stock pads, when hot, and my Axxis Metal Masters, when cold (and/or wet). Pedal firmness is 100% improved with the lines. Now, I do have one caveat, as the rotors and lines I took off had 265,000 miles and the pads had 120,000+ miles. So, rather like installing any new set of plugs versus your old worn out plugs, there will always be a difference.
Concerning cross-drilled rotors, I decided on c/d for water evacuation, as opposed to improved cooling. In Louisiana, we do drive in our share of showers and puddles, and I absolutely hate that uneasy, no brakes feel on the first application. As I mentioned before, I don´t think extra cooling is that big an issue for me, as is evidenced by the stock, unturned, true rotors.
Have fun making the decision, whatever you decided to do.
Marcus
what´s up with the miata, not an escort even if it does have a mazda motor.
_________________
[ Edited by stripedmx5 On Date 10-10-2002 ]
