How do I turn up the idle on a93 lx
The TPS is a set/fixed calibration on the escorts and really needs no attention unless the voltage (when checked by a multi testor) is below or above spec. The IAC valve can be removed and cleaned.pistonslap said:Is there any adjustments that can be made on the air idle miture or the throttle position control? I just priced them both at pep boys $449.00 for the AIM and $143 for the TPC. If there is an adjustment on either, I like to try that first.
