1 - 4 of 4 Posts
Car: 1987 Escort GT, 88 Head with Roller Cam and lifters.
30 thousands on head
Ported to match gaskets and polished
STOCK SUSPENSION
Can't seem to catch this built 2.2L Cavalier running alcohol and lowering suspension...
Anything I can do to make it rotate better in the corner?
I'm getting spring rubbers but anything i can do to make it run the bottom line of the track with no problem?
Car doesn't want to rotate off the corner that well
any way to pitch the rear end easy?
Spring swaps?
TRACK IS A BIG 3/8 (HIGH BANKED)
anything will help! THANKS!
talk to dirtrackracer25 he know everything setup wise and i use parts off his setup, he know his stuff and could help you out
1 - 4 of 4 Posts
