1 - 7 of 7 Posts
Hey All :D
For any of you who have access to a Princess Auto location and need or want the turn signal and wiper switch unit here's something for you. They are currently selling surplus OEM turn signal and wiper switch assemblies for the escort for 14.99 cdn$ :shock: They appear to be for third gens, but I picked one up for my second gen as I believe they are the same switch. For $14 I couldn't go wrong, they're usually 10 times that price anywhere else. If anyone can confirm that the second and third gen switches are identical that would be great. The only way I could see them being different is if the harness mounts got changed. Other than that they are physically identical.
Unfortunately they don't have the part lised online, so you'll have to go to the store. Follow the link to find one close to you.
http://www.princessauto.com
They have both the standard and variably intermittent styles as well, so if you want you can upgrade for $14 :wink:
Matt 8)
They are $20 used at my local U-pull-it junkyard. Just make sure you get the one with the extra wire in it for cruise control. I had to add the wire for mine when I added factory cruise control, but if your going to buy new then you may as well get it.
I may be wrong, but I believe the module for the intermittent wipers is on the switch assembly itself. The difference between the two styles other than the additional switches is there is another 'module' on the back of the intermittent style switch.
Matt 8)
MadBrad said:
To upgrade your wipers to intermittent, you need the module in addition to the stalk. My cruise is on the steering wheel. What cruise are you talking about z?
Yes, I was referring to the fatory cruise control on the steering wheel.
I added it to mine.
1 - 7 of 7 Posts
