1 - 9 of 9 Posts
ok say I have a 91 EGT...I bolt on a turbo...how much psi can i run with everything stock...how do i go about changing psi on a turbo...and how do you change compression ratio in engine to run more...
See you guys missed a key word in my post...the word "stock." I have completely stock. I want to add turbo...I will add the other shit as I go but I want turbo on now. What can a complete STOCK motor take
To change the boost pressure produced by a turbo you need to adjust the wastegate. That means you can go from everything from a one-way valve from home depot, to a $700 Apex´i AVC-R.
Right now I´m going to be using a simple valve, but planning on upgrading to a TurboXs 2 setting boost controller.
1 - 9 of 9 Posts
