Turbo on stock manifold. | Ford Escort Owners Association (FEOA)
Discussion in 'Forced Induction & Nitrous' started by austin86, Aug 6, 2020.
  1. austin86
    1,103
    358
    118
    Ohio
    I don't really know much anything about turbos. But I was thinking, would it be possible to put a little trubo on the stock escort cast iron manifold with an adapter of some sort?
    EDIT:
    I probably should state that I do not plan to trubo a car. I just wanted the into for a possible build way down the road.
  2. marclar
    9,061
    604
    seabeck WA
    yes, it has been done
    austin86 likes this.
  3. austin86
    1,103
    358
    118
    Ohio
    Is there any reason not to do it? Aside form other options being available. In other works is is hard on the manifold or really bad for performance?
  4. marclar
    9,061
    604
    seabeck WA
    welding cast can be tricky... the welds become brittle and dont handle high heat so well. often they would crack and turbos fall off. bracketry becomes required. other issues are the turbo sits very low and does not have quite as good of oil drain.
  5. austin86
    1,103
    358
    118
    Ohio
    Thanks for the info. I was thinking of more of a bolt on adapter assuming I can find a trubo manifold for the 1.6l I wanted to build down the road.
  6. novanutcase
    novanutcase FEOA Member
    2,605
    621
    263
    Not a 1.6 but this kit for the Zetec would be awesome if it was still available.
    [​IMG]
    or this
    [​IMG]
    John
