wanted to double check.... the gtx turbo manifold will be a direct bolt up swap to the 1.8 egt right?
yes direct bolt up!95EsCoRtMan said:wanted to double check.... the gtx turbo manifold will be a direct bolt up swap to the 1.8 egt right?
BF GTX is 1.6lOnegimp said:Depends which one you get, so yes and no.
