1 - 6 of 6 Posts
is this right to start off with? 5psi
exp manifold
FORD Escort 84-86 IHI RHB5
Boost Gauge
EGT Gauge
Oil Pressure Gauge
Fuel Pressure Gauge
FMU - 12:1?
BOV
FMIC
IC-Pipe
anything missing?
-Clutch relocation brackets (see jeffs cardomain)
-Lots and lots of time :)
-Coolant "T" fittings and hose for tapping into heater core
-Are emissions an issue? If so you'll need a high flow cat
-1 or 2 stage colder spark plugs (don't run stock heat range you'll fry them)
-A welder to fab up all the custom exhaust and intake piping you'll need
-10" Pusher fans as your stock one won't fit anymore
Are you doing this on a second or third gen? Doesn't make too much difference but I was curious
You'll need a custom down pipe.
Either modify the PCV tube you have now or grab one off a 2.0 and work with that.
You dont really need a oil pressure gauge. The IHI turbo's can handle the CHV oil pressure just fine.
I'd ditch the EGT gauge and just save up for a wide band, it's the best way to monitor A/F. Dont really need to dyno tune if you allready have your own.
You dont really need to run coolent right away, it's a good idea, but not needed.
and yeah you'll need a fan, oil lines and the colder plugs and higher octane.
1 - 6 of 6 Posts
