1 - 3 of 3 Posts
i dunno
I am not sure never really seen under the hood of the miata but i heard on a previous post that it wont.. sumthin to do with the way the miatas motor is mounted like the header is in the other side of the block or sumthin. and alot of what you pay for is the freakin bent pips that wouldnt even work so i say just make a kit exactly how its needed
yep!
the fact the the miata is a rear wheel drice so the motor sits 90 degrees off from the front wheel drive scorts!
if you have no problem with smog in your are, just order a gtx motor with the turbo, by the time you are done you could spend less than 2 grand for a motor that can handle the more power of turbo!
and for a cheap motor hit the junk yards, plus i think the zx2 front mounts are th esame as the gt!
1 - 3 of 3 Posts
