So I figured I would do a simple hub replacement because it was making some noise. Started off fighting the screws on the drum. Next the hub asembly seems to be frozen in place so I took a small puller to it and it popped without too much pressure. I am guessing the bearing over heated and pretty much welded the inner race to the axle stub. Fast forward a couple hours to where I am wishing I pulled this in the garage to work instead of the driveway. I opted to remove the rear asembly but I am stuck on the lower bolt that holds everything together on the bottom. I have stuck a nice sized breaker bar on it and slapped it with a 2.5# hammer. Anyone ever have to fight this thing out? I am thinking heat and a sledge but I am sure I'll end up breaking something else in the process.
