1 - 6 of 6 Posts
Greetings,
Just brought a new (to me) 1998 ZX2 for my daughter. Little car runs good @130k but the automatic transmission is DOA. Fluid is blacker then used engine oil and comes with the complementary burnt smell that stinks up the whole shop.
Bought a factory shop manual for it off of eBay but won’t be here for a few days.
Never had the privilege of working on a front wheel drive trans axle so forgive me if this is a dumb question but can the trans axle be changed with out pulling the engine?
Great web site I am sure I will be reading it often.
Thanks
yes, it can be removed without taking the whole engine out.
I actually started to make a how-to video for ATX and MTX replacement. Then my computer crashed and took the 22 hours of work I spent on the video with it.
A good jack is a must. You can do this alone but only if you have a really good jack or you can bench 400 pounds.
Man a video would have been sweet! I think my ATV jack will work, its not as good as a real transmission jack but it will do.
Thanks for the replies.
The couple FWD cars I've worked on doing a clutch repair, I think it's about as easy or easier just taking the engine out and working that way. But I have a cherry picker, so that may be why I think that. You do a lot of wrestling leaving the engine in. I'm sure you'll get some arguments here saying otherwise, but I'll bet most don't have the equipment to pull the engine.
It is certainly easier to do tranny work in the ATX with the engine out. But, if it was a MTX, it would be easier to leave the engine in. The overall cost of doing it engine out is a bit higher and might take a couple hours longer, but it is less physically demanding to take the engine out.
1 - 6 of 6 Posts
