Hi guys.
I have a 1998 Escort ZX2 auto.
I have searched for a few hours to see if anyone else has had the same symptoms as this but not found anything.
This is the story:
After the last oil change my wife was advised to change the transmission fluid as well. (I didn't have time to check to see if the tranny fluid smelled burn't.) She did and two days later she called me saying that the car wasn't working. We called the guys from Jiffylub and the car started working. The guy said there wasn't anything wrong. But few days later the car stopped working again. The engine starts, you can move the stick to any gear but the car doesn't move. It seems that it is always in the N (Neutral) position.
My mechanical skills are getting better so I would like to attack this myself, I've done driveshafts and wheel bearings so I suppose this is next!
Do these symptoms sound like a catastrophic gearbox remove to fix failure or does it sound like a switch/valve/solenoid type of thing?
Thanks for any advice. I know it's pretty much impossible to diagnose things from a computer screen.
Nathan.
This is the story:
Nathan.
