I have a 93 manual GT with only 66,000 mi on it. Over two or three days most if not all trans fluid leaked out. The bottom of the tranny around the drain plug is where the drip is but it's not the drain plug. The trans works fine. The only thing i can think of is three days before, i had to go through about 15" of water. Is it possible the fluid is coming from the Axle? Any help would be much appreciated. Thanks
