1 - 3 of 3 Posts
I replaced the clutch in my 95 LX Wagon. I drained the Trans-axle and found that the oil smelled like gear lube. Looks like it too. My book has Mercon ATF listed for it. What is the best fluid for this Transmission? (How much too) I never had any issues shifting this car in 60K Miles. Anyone help me?
ATF it recommended, but I've had gear lube in my '88 for years. The only problem I've had with the gear lube is that it shifts a little bit stiff on really cold winter mornings. When refilling it just fill it till the fluid starts running out of the fill hole.
1 - 3 of 3 Posts
