transmission fluid for a 5 speed? | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by 4doorscort, Jun 26, 2012.
  1. 4doorscort
    4doorscort New Member
    8,129
    5
    Brampton ON
    about to do the famous 5 speed swap this weekend wanted to know what you guys suggest for oil. I was told to use some heavy gear oil for diesel trucks, its a tad on the pricey side and this project is sort of a must right now leaving my pockets fairly empty.... so I'm looking for something fair priced that is decent quality
    thanks
  2. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    Gm syncromesh if you can swing it.
  3. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    ^^that or I have had great success with quality synthetic ATF.
  4. 4doorscort
    8,129
    5
    Brampton ON
    brand? prices?
  5. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    I use BG products fluid. It a "professional" grade fluid sold to repair shops. IIRC, BGproducts.com is the site. The area rep rolls in every few weeks. Their cleaners and conditioners are great too, use them in flushes all the time. IDK prices, bossman lets me snag a gallon's worth when I need it...
  6. 4doorscort
    8,129
    5
    Brampton ON
    looks like good stuff but I don't think we have that in canada land
  7. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    It's easy to forget that you're a maple leaf brother, LOL.
  8. FordMan59
    FordMan59 FEOA Member
    4,547
    441
    333
    Russellville, Kentucky
    I've got gear oil in my '88 Pony which works fine, but the shifting is a little bit stiff during the winter. I've heard of people using synthetic motor oil in manual transmissions, but I've never tried it.
  9. vtec-this
    vtec-this FEOA Member
    1,577
    6
    288
    Brampton Ontario
    i usually use 75w90 gear oil and thought the trans was supposed to be "clunky". just put in ATF synthetic with the last trans and it is much smoother.
    used Valvoline synthetic atf
  10. 4doorscort
    8,129
    5
    Brampton ON
    cool, I think I'm going to go with the atf stuff
  11. jj93egt
    jj93egt FEOA Member
    383
    166
    Spotsylvania, VA
    D6 ATF.....better MPG in theory....everyone said it was too thin....I took a chance...crossing my fingers!!
  12. StealthStyle
    StealthStyle FEOA Member
    1,152
    186
    Cali
    ATF works great. Just make sure to get the right kind (check the manual).
  13. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Dextron/Mercon Syn. or non.
  14. Willeh
    Willeh FEOA Member
    84
    9
    108
    bc Canada
    i run royal purple syncromax its amazing stuff
  15. 300ZXRB26DETT
    300ZXRB26DETT FEOA Member
    1,012
    21
    288
    PHX, AZ
    ATF for cold climates GL-4 gear oil for warmer weather.
    Ford calls for ATF, Mazda calls for gear oil in the same transmission. You decide whats best for you
