1 - 3 of 3 Posts
Assuming this is only happening in fifth and is distinct from a slipping clutch (ie it is actually popping out after being in gear), then yes. The teeth on the collar/gear for fifth are worn. Have you checked for filings in your tranny fluid? If it goes into fifth really easily (ie with little or no clutch assistance), then you can be really sure.
1 - 3 of 3 Posts
