1 - 6 of 6 Posts
I replaced the tps the other day and now when after i push my gas pedal down a little bit it will start to shake like it's not getting enough fuel. I reset the ecu thinking that might help but it didn't. The old one didn't do that but it wasn't making the tranny shift right. I'm clueless right now.
nice avatar... very sexy
sounds like your VAM is unplugged. If it idles fine but chokes when you open the throttle it's either
1. VAM not plugged in or dead
2. torn intake tubing (somewhat common in older scorts)
well thank you.....i guess it beats what i had on here
i did change both sensors on the thermostat housing so i had to take the whole assembly off all the way up to the throttle body. I might have done something there when i took out/put back in the intake.
1 - 6 of 6 Posts
