Tire Size Calculator + Wheel Bolt Patterns by Gen. | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'Wheels/Tires/Brakes' started by 1Sleepy93, Sep 14, 2004.
  1. White_Wolf
    White_Wolf FEOA Member
    407
    166
    Downtown Traverse City
    Re: Tire Size Calculator
    I've found a BETTER SITE : http://www.discounttire.com/dtcs/infoTireMath.dos
  2. silentnite2608
    silentnite2608 Guest
    162
    samurai-kitty likes this.
  3. fivptgo
    fivptgo FEOA Member
    15
    153
    sacramento ,CA
    looking to see what other ford 4-lugs will fit my 89 egt
  4. 95EscortDriver
    95EscortDriver FEOA Member
    1,181
    186
    Hubert, NC
    Dude, lug pattern On Second Gen/3rd Gen/ZX2 is 4x100.
    Basically, Most Honda Civic rims will work. So just think, NE rims U see on a 4 lug Honda Civic, U can't use.
    The 1st Gen Escorts use a different Lug pattern, I think similar to the 2nd gen Prelude, Accords, and Toyota's, and older 4 lug Mustangs.
    BTW: Read the 1st post in this thread and U would have saved me and U the trouble
  5. LowriderS10
    LowriderS10 New Member
    246
    What's the stock backspacing on a '93 Escort wagon?
  6. LariRudi
    LariRudi FEOA Donator
    2,341
    219
    313
    Backspacing/Offset
    What's the difference between backspacing and offset; are they the same? Where are they defined?
    thx,
    LarryR : )
  7. LariRudi
    2,341
    219
    313
  8. Pidge
    Pidge New Member
    41
    Kiel, WI
    I just got a pair of aftermarket wheels (16") with 205 55 R16 Hankook and omg they could not get any closer. I got less than a pinky with between the inside side wall and rear strut and even less in the front. On $250 for the whole set with tires so I grabbed them. Deffinatly could use a set of spacers.
  9. LariRudi
    2,341
    219
    313
    Hmmmm, me the opposite
    Me, what do I have [even I gotta see above, but I think 205-60-14; let me check for SURE] and mine are a SKINNY pinky from the fender lip on the back.
    I always DID drive like an old man, but now I've gotta go slow over the bumps or the fender rubs the tire.
    We can learn from each other; do you know how to measure the "backspace" on your wheels?
    I compared my wheels to the factory steelies and I'm only 3mm further OUT, but of course the tire width comes into play, too.
    [Edit; not further OUT, but further IN; like, GOOD THING the backspace was NOT the same as my steelies, or the fender would NEVER miss the tire; for clarification; the cast wheels have 3mm MORE backspace than my steelies, which puts the new cast wheels' tires CLOSER TO THE INSIDE. Of ocurse the 205's are wider than my stock tires, but we're talking about backspacing now; sorry for the confusing statement above]
    Good luck to us both, ha.
    LarryR : )
  10. juggalo
    juggalo New Member
    6,096
    11
    Tacoma, WA
    u might wanna consider rolling ur rear fenders
  11. LariRudi
    2,341
    219
    313
    Rolling Fenders
    I've seen "you guys" mentioning that on some other threads and I'm only guessing that it means "folding" that lip back UP ONTO the fender so it's completely out of the way? and does NOTHING to the external appearance of the fender [unless you'e an ant looking up?]. So is there a special tool for that, or pliers, vice grips? what goes? I mean, what do I need to get/borrow and how do I do it then?
    thx,
    LarryR : )
  12. LariRudi
    2,341
    219
    313
  13. redevil
    redevil New Member
    20
    canoga park , ca
    whats the offset on the 3 gen?
  14. 97MTracer
    97MTracer FEOA Donator
    469
    27
    178
    Central IL
    so basicly i can take my brand new tires off my 3rd gen and put them on my 2nd gen just by taking each wheel off and swaping?
  15. adarkang
    adarkang New Member
    Will 205/75/R14 tires fit a stock 97 escort LX? My stock tires are 185/65/14. My friend gave me 4 brand new tires a while back but haven't had the chance to mount them onto my stock rims.
  16. madmatt2024
    madmatt2024 FEOA Member
    9,842
    403
    383
    Upstate N.Y.
    There is no way you are going to get those honking things on there. Sell them and buy the correct size.
  17. Irie
    Irie FEOA Member
    47
    36
    What would be the best size tires to put on my stock 13 inch rims for my 91 LX
  18. madmatt2024
    9,842
    403
    383
    Upstate N.Y.
    The factory size. There are not many options other than that in 13".
    Specialk likes this.
  19. Irie
    Irie FEOA Member
    47
    36
    The size Austin's I have to choose from are
    175/70
    155/80
    165/80
    What do you guys think would be the best option performance and drivability
  20. madmatt2024
    9,842
    403
    383
    Upstate N.Y.
    As I said, the factory size. 175/70r13.
