I believe access on a first gen was good enough, since I did it several times on my 1985GT (1.6L engine). But on the newer 1.9L engines, and possibly others (probably more like everything from 1991 the crossmember gets in the way). Generally speaking, removing the transmission pan involves jacking up the engine/transmission and sometimes removing the front transmission mount bolt in the process. But even then, the crossmember still gets in the way somewhat. I was able to do it with a wrench and a regular ratchet. But if I had to do it again, I'd want some more tools.
I did happen to have a flexible extension, but it's really only of limited use. Specifically one of these:
I was wondering in anybody used any of these, and can you report back it's effectiveness:
Regular ratcheting wrench:
A flex ratcheting wrench:
A flex socket:
Or maybe a wobble extension (not pictures since it looks too much like a regular extension).
So I am curious as to how some of you might have gotton off some of those hard to get off transmission pan bolts (for those who did it with the crossmember still on).
A flex socket:
