Timing lights???? Those should be in your tool box. What engine do you have??? As far as timing marks go, on the 1.9 they are on the timing belt cover. they look something like this:
vvVvvv
The other mark is on the pulley:
l_l
There are two on mine use the smaller one, the bigger one is for sometihing else. It is a good idea to use a vacuum guage whil you are timing you car too. If you get too advanced the vacuum will drop off and you will loose power.
If that info helped feel free to Donate.
[ This message was edited by: Pimp_scort_89_GT on 18-04-2003 21:00 ]
