No, I dont think it was the timing. Besides Its hard to tell with my scort. I blew the timing belt down at 1k over sea level, and I had been at sea level for a week, then I drove back up the hill here to 5500´. The altitude makes everything a little weird. And even now I´m forcing the timing to be retarded a little bit so I dont have any problems with boost.
Almost forgot, after the turbo is all in and I have the interior cleaned up. I´m buying a new motor. I want to port and polish the head (my friend has a flow bench). re-do and upgrade the valves, seals, springs, etc. New cams. I want a cam that has a little more duration on the exhaust side. I´m aiming for a VE of 95-98%
My friend Rob wants to make a custom sheet metal intake too. Also with higher flow characteristics.
I think we´re aiming for the bottom end: 4" stroke, bored .03 over. Try to get the displacement somewhere between 2.5-3.0L. Rob knows a company that can make the crank, rods and pistons.
Its probably going to take me a year or two to get it all together. I´m guessing its going to cost about $6-7k and thats with doing alot of the work ourselves and getting hooked up by this company.
well the ultimate goal is to go from 127hp to about 350hp. And 114ft-lbs to about 300ft-lbs.
_________________
Jason Blade
93´ Escort GT (Special SLO model)
[ Edited by TheBlade On Date 11-05-2002 ]
