Ok, so I have the car in my shop and up on ramps, ready to change the timing belt and water pump--- and already I'm running into some issues. First off, do you guys do all the work from under the car, or from the top? If from the top, theres several hoses (a/c, power steering, etc) that are in the way, and even after removing the brackets, they don't wanna move much. Looks like I'll need to move these hoses, remove the serpentine belt tensioner, the crank pulley, and the passenger side motor mount just to get the timing belt cover off --- and then still won't have much room to work. If working from under the car, I'll need to remove the right front wheel and the splash guard and still won't have much room to work.
Can any of you post a quick step-by-step procedure for this? I've read alot of posts that say this is an easy job, but I can't see that its "easy" even just to get the cover off, much less working in there once it is. Thanks for any help!
