Back on the forum after quite some time...didn't even remember my nickname, so I had to re-register...
1. Is it absolutely necessary to remove the crankshaft pulley? If so, I read there's some sort of inspection plate near the rear of the engine that you remove to put a prybar to the flywheel/driveplate teeth to keep the engine from turning when you remove the front bolt. A little more info on this cover? Also, if using an electric impact gun (~140ft-lb max), do I even need to worry about holding the engine from turning? What about lets say an 800ft-lb gun? I would like to ideally not take out the crank pulley (I'm thinking the crank angle sensor may be in the way for the belt to pass), or at least not have to hold the engine from turning.
2. There was a thread where the OP posted a how-to. He pried the tensioner against the belt after reinstalling, while tightening. I thought you only had to loosen the tensioner, let it pop back, rotate the engine two turns, and tighten the tensioner, essentially letting the spring do it's job?
More questions may follow if I remember. I have the car half apart, so any help will be very appreceated.
Paulo
93 Escort LX 1.9 Air, Auto
Paulo
