1 - 9 of 9 Posts
any one do a tilt steering column swap if so whats involved i got a 94 gt with a bag and im puttin in the 93 gt w/o bag but w/tilt .
im just asking how long basically it takes i dont wanna rip it apart and take all day never done a column b4 i just need it to fit in with my mx3 seats im short and the wheels to high and now i got a parts car
It's a direct swap. Go under the dash and up to the firewall where it passes through. Take off that plastic cover. In there you need to undo the torx bolt that holds the column to the steering rack. I don't know the exact size of the torx but it's pretty big. After you get that loose then take the plastic surround off from behind your steering wheel. Look under there and you will see 4 gold bolts holding the column up. Take them out, and then the column is free. Now just swap all the components from one to the other or just swap the wires if you have all the components already on the new column. Then reassemble and tilt away.
Yeah, I would want to try and swap the airbag wheel onto the tilt column. And don't forget good old Uncle Sam gets a little more picky about auto safety features every year. Since you have the tilt column sitting there, see if you can get away with swapping the wheel (and the ignition). Don't forget the ignition. Much easier to do when the column is out of the car.
1 - 9 of 9 Posts
