1 - 6 of 6 Posts
Anyone know if you can swap out the insides of a non tilt colomn into a tilt cololmn so that you can use your same key off the non tilt in the tilt? Or is there some kind of anti theft stuff?
Thanks for the help
If it can be bolted on, it can be removed. Just do it.
You'll need to take the lock cylinder off of your column. I don't remember exactly what they are, but they are not common screws. you might have to dremel a slot in them to take them out with a screwdriver. Then just replace them with regular screws.
--sarge
1 - 6 of 6 Posts
