2k mi ago I had the front passenger wheel off when I did a cyl head swap and had to set the timing. There was no (or very little) wear on that tire at that time. Today I did an oil change, and found that the outside inch or so of the tire is worn right down to the end of the wear bars. It isn't evenly worn all around, it is worse on one side. It looks like there is cupping on the outer edge.
Over the past week or so, I've noticed while making left turns and accelerating I get a kind of light rumbling noise that sounds like it's coming from that wheel. Kind of a bump..bump..rattle like going over a rumble strip slowly (but much quieter). I tried to check the tie rod and ball joints on each side in the front by wiggling side-side and up-down. Up-down has no movement on either side. Side-side has no movement on the driver side, and a very slight (barely noticeable) movement on the passenger side (ie. the side with the excess tire wear). I can't notice any movement wiggling the tie rod with the tire off.
I'm curious if this ever so slight movement on the passenger side could mean a bad tie rod end, or the other possibility, did I forget to tighten the lugnuts fully on that side 2k mi ago? I put everything back together kind of hastily because I had been working on the car all weekend and needed it that day for work, so I may have just tightened them half way, dropped the car off the jack intending to finish it, but forgot.
So.. could a tie rod cause THAT much wear in the course of 2k miles? Like I said, the other side of the tire looks brand new, but that edge is worn to the end of the wear bars in one spot. For the time being I've swapped it with a back tire as I keep an eye on it.
