1 - 9 of 9 Posts
how do i remove the throttle cable from the pedal?...my throttle cable broke yesterday when i was going home(good thing it broke when i was on my driveway.)...any help will be greatly appreciated.....thanks.....++==
hrm. Interesting.
Well I know you could use the cable and cable housing from a bike. I used to do a little work in the bike shop and the cables are similar. You could get some pretty smooth travel if you used some nice cable... even though it is kinda ghetto.
Both ends are for the most part the same thing (as far as I remember). Take the pressure off of the throttle body plate by manually opening it, you can then "bend" the cable forward (towards the driver's side) and slide the "ball" on it through the hole, thus loosening that end. It's pretty much the same process on the gas pedal, but it's much easier to do once you've removed it from the throttle body.
1 - 9 of 9 Posts
