thermostat or head gasket | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by jim93escortwagon, Feb 21, 2008.
  1. jim93escortwagon
    jim93escortwagon Guest
    7
    my car starts up and idles rough. i can hear almost a clicking. when it starts to warm up it begins blowing white smoke from the tailpipe. it never really warms up though. the heater blows lukewarm air. i just replaced the thermostat, so is it possible that i did it wrong? i saw some of that oil/coolant mix going into my heater core tube, but i thought that i would have got that out with the coolant flush that i did after the thermostat was installed.
    is there a way to install the thermostat wrong so it stays open?
    is it possible to just have buildup in the heater core? if so, to flush it, do you have to pump water directly in there?
    why would the car only begin to burn coolant after it starts warming up? does that mean theres a crack in the upper part of the head?
  2. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
  3. Berek
    Berek New Member
    29
    Dunedin Florida
    Yea your head is toast.THe gasket probably swells and reveals a good place for the antifreeze to go out is why it smokes after it gets warmed up,or mabe the crack in your head is somewhere around the water inlet and it waits till water is circulated by the thermostat
  4. DeathSlinger00
    DeathSlinger00 FEOA Member
    2,596
    288
    Elyria, OH
    yep, sounds like a blown head gasket to me. did you pull out your oil dipstick to check and see if the oil looks like chocolate milk? that (along with smoke out the tailpipe and cold/lukewarm air out the vents) is usually a telltale sign. oh, and check your coolant level while your at it.
