Theory Warning: Super-efficient Intercooler | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'Forced Induction & Nitrous' started by mp3scort, Nov 23, 2005.
  1. jet-lee
    jet-lee Guest
    780
    I'd thought about rerouting the freezing cold a/c lines that run around the hood line, to go through the throttle body coolant passages to cool down the throttle body. But then I was reminded that r134 is combustible, and the heat from the engine heating it up probably isn't a good idea. I scratched that thought within the day.
  2. TitoElSpicco
    TitoElSpicco Guest
    1,078
    I'd like to see a video of a truck running a low 12 and trapping 110.
  3. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    Look up Parish turbo silverado on the web. His runs a 10.09 at I think 146 or something stupid like that.
  4. NYinThaBuilding05
    NYinThaBuilding05 New Member
    1,171
    Poughkeepsie, NY
    there a ford powerstroke vid floating around out there somewhere............it ran high 9's and low 10's all at well over 110mph..............so its beleiveable!
  5. mp3scort
    mp3scort Guest
    471
    r134 and r12 when exposed to open flames will produce a toxic byproduct, but only when exposed to an open flame.
  6. NYinThaBuilding05
    1,171
    Poughkeepsie, NY
  7. NYinThaBuilding05
    1,171
    Poughkeepsie, NY
    let me know if ur a beleiver after the vids, lol!
  8. NYinThaBuilding05
    1,171
    Poughkeepsie, NY
    the 3rd one ran a 9.06
  9. vtec-this
    vtec-this FEOA Member
    1,577
    6
    288
    Brampton Ontario
    beh, just inject methenol. If your pushing so much boost that your FMIC + injection needle cant even come close to cooling the charge just get a bigger needle and properly sized intercooler, pretty simple. + No drag. And to give you a guys a perspective of something called diminishing returns from intake temp, I spray my FMIC with a hose and let it freeze overnight for the drive to work in the morning. With a thick layer of ice on the IC you get maybe a 10HP difference MAX unless you are boosting over 20PSI, I dont see the AC cooler outperforming a iced out FMIC so why bother. The lighting would have made the 75HP with a good intercooler anyways, it was more of a band air i thinks.
  10. mp3scort
    mp3scort Guest
    471
    but with the ice on the fmic, the core can be damaged since ice expands and can crush the air passages, lowering the flow of the intercooler.
  11. vtec-this
    1,577
    6
    288
    Brampton Ontario
    never had a problem in the 2 years ive had it icing it in the winter. Looks like new. What do you think would happen if it rained then got cold..? anyways, the point i was trying to make is that you are going through too much work to get 10HP. Click your boost up 1 psi when you get a good FMIC and you made up the power right there.
  12. mp3scort
    mp3scort Guest
    471
    the whole point isnt just power, but no knocking as well.
  13. vtec-this
    1,577
    6
    288
    Brampton Ontario
    very true. look into meth injection if you are worried about deto or cant get 94 pump gas.
