81 - 100 of 139 Posts
Many put a breather filter where the PCV valve is and plug the nipple at the other end of hose. Some have installed PCV oil catch cans to collect oil that would be introduced into the intake through the PCV system. Never had an issue with mine, so it remains stock and maintained.
Are you saying you can Plug the top hose on the PCV and put a breather filter on the bottom hose, Thereby removing the PCV hoses completely? I've been having trouble with my PCV hose breaking constantly, and don't feel like buying the $45 new hose.
NYinThaBuilding05 said:
I'm assuming u have a 3rd gen for this one........take out ur center console so u can get to ur ecu.......look for a white wire with black stripe.......find it, cut it, and put a switch on it....mount the switch where ever ud like......do u have an auto or manual?
What is the purpose of this mod?
1998 ZX2
To disable the speed limiter.
UPDADTE**
real 3 inch CAI (into the fender w/fender cut)
3.8tb (70 mill tb coming soon with custom intake mani)
ported maf
ported intake mani, spi runners, exhaust manifold
drilled out cat with straight through "muffler"
egr, a/c, p/s delete
msd coil pack
180 thermostat
8.5 mill wires, ngk plugs
egt rear sway bar
b&m short shifter
poly bushings
one way (lower) pcv setup
simple wire tuck
18" core racing rims (not sure bout the tires...but they are lowww profile)
customish black & tan interior
tracer front bumper
:D
i am going turbo this spring, and have a whole lot more planned, so far ive accumulated; td05 turbo, oil cooler, all the plumbing, fuel pump, mustang maf and injectors, external fuel cell, braided fuel lines, heat wrap and some other stuff...im getting soon; manifold, bov, intercooler, rocker arms, valve seats, valves, springs, clutch, upd,.......and eventually after a bigger turbo, ill be switching to a standalone unit :D :D :D
1998 ZX2
shaepozy said:
I wanna customize my interior, and try to get a cd player put in. im sick of the tape deck. can i plz get some help?
Dude, this thread is for engine mods!!! Read the title before posting.
I had the same problem as you do with the tube. My stock one was getting old and Seafoam made it collapsed. I went to Lowes and lol bought a air hose and it collapsed from the heat. I then went to Advance Auto Parts and bought a radiator hose that fits the pvc valve and it works great. Been that was for 9 months or so. Still holding up. I zipped tied it too so the bend is less on it. Hope that helps you. I think I spent around $10 or less. The one I got was a pre-cut one.
Thank you.
ok first off do something they call blue printing finding the best parts with the best fit it was what they had to do for road racing in the beginning when they were only allowed stock parts every manufact has specific "tolerances to size of pistons ect or else there would be excessive waste" including con rod weights so yeah balancing is a must coming from somone who works on engines daily bike and car, it may seem better balanced but its not ford never assembled these cars by hand taking time to perfectly align and weigh everything they had machines throw it together with tolerances to +or- actual need every little tiny bit counts
tighter fitting bolts, using grade eight cap screws with hardened washers waisting fasteners (lightens a lil bit and also lets the fastener strecht preventing failure and fatigue) increasing fit by making surface to surface joints using a modern sealer and milling surfaces to match. compression and crap like that is not good if the cam prophile and dynamic compression is not matched anyone needs the formula its dcr=(swept volume at point of inlet valve closure+clearance volume)/clearance volume
Customizer
#UPDATE-Performance MODS:
Ported Head & Intake
IntakeManifoldRunnerControl Deleted Plates
or RPM switch SPI Controller
3.8L TB
5.0L MAF
COLD air Intake w/ Pod filter
Adjustable Fuel Pressure Regulator
High Performance Fuel Pump and Fuel filter
Quartz Crystal Fuel Line MOD
OBX Headers
Hi Flow Cat and Muffler
Spec Stage 3 Clutch
Performance Tires & Wheels
or FORCED INDUCTION:
T3/T4 Garrett Turbo
External Wastegate w/ dump pipe
Intercooler
CBV or Diverter Valve
Turbo Timer
Boost Controller
Megasquirt II for high PSI
FordRacing #42lb Fuel Injectors:rage:
Customizer
I was looking around on zxtuner and I found a BlackBox that hooks up to your PCM and adds up to 16hp at full throttle to the 2.0L's. They say it's one of the best performance mods you can add to your escort for under a $100. I was just wondering if anybody else had seen it or has it and what you think about it, so check it out: ill be here:sleep:
http://zxtuner.com/product.sc?productId=188&categoryId=18
why dont ppl understand that double valve springs take double the power to open???? unles you plan on spinning it 7500rpm you dont need double springs.
Not necessarily. Coming from the 10K-rpm+ motorcycle world, double valve springs there were used for two purposes: 1) to provide the same seat pressure without a huge single coil (which would bind), and to prevent resonance from creating float. With one spring at one coil 'frequency' and the other at another coil rate, you can avoid float as one overlaps and takes over during the resonant freq of the other -- total seat pressure doesn't *have* to exceed a single one, but they commonly do. Even better are beehive springs, with a tapering diameter as well. ;) I do agree with the last sentence, though... get dbl springs if you plan on keeping it at power peak and beyond for roadracing, not for 'cred'.
Technology Will Rule The World One Day
I have T130 Split Port Controller. This modification makes a huge difrence. It gives it a somwhat V-Tec effect.
My car has 211k on her with my valve seat problem fixed on the OEM head, for now. I think if I did get that BlackBox, I would blow my engine. I get up on it 3k RPMs or so and rearly hard but she runs so good. I have catback exhaust and modded OEM CAI. Is there a video of this BlackBox in action? I am not sure if I would be better off getting a ZX2 engine and rebuilding that vs my SPI. Machine work is costly.
videos are on edmonds
do a L5-VE swap. it will require minimal mount modifications, and is much better motor. 150hp stock. L5-VET is 190 -200 hp debending on boost set up. Got the idea from my friend across town, he did an L5-VET swap into his 97 SE
1998 ZX2
^Pics of swap? The intake and exhaust on that motor are swapped which could cause some interesting fitments issues, not to mention the cable shift trans and CAN bus ECU.
  • Like
Reactions: ndlm8888
