1 - 7 of 7 Posts
I got an SPI maf. But the plugs are different and the colors are too. What colors go to which. I just set them up in the same order from left to right.
It seems to have no hesitatiopn at all now. But idle is a little bit funky. If anyone can let me know the color codes it would be great too see if I have mine setup right.
Thanks
John
Did you pull the battery cable for 60 seconds to reset the ECU? If not, you might try that. :wink:
is the 4 wire plug and there is no abcd on any of them
I reset the ECU as well. and now it doesn't even run at all...I'm back with the 1.9L maf.
John
On the MAF itself is the ABCD. So the connector will need to be pluged for you to see the order.
1 - 7 of 7 Posts
