Drivetrain - the socket for front axel nut? | Ford Escort Owners Association (FEOA)
Drivetrain the socket for front axel nut?
Discussion in 'Tech & Repair' started by headmn, Jul 27, 2020.
  1. headmn
    headmn FEOA Member
    15
    6
    Help someone before i kill myself. i am on my way to the
    parts store by bus, for the 3rd time to get the RIGHT %$#@*&%$
    1/2" drive socket for the front axel nut. can someone tell me plez,
    whats the rite size; its not 27,28,29 or 30mm? my '95 1.9L scort
    CV job awaits me. thx you,headmn
  2. Gamer92
    Gamer92 FEOA Donator
    3,469
    1,006
    313
    Southern Indiana
    Should be 32mm
    zzyzzx and Swift like this.
  3. Swift
    Swift FEOA Donator
    528
    111
    293
    ^ yep, that it is
  4. denisond3
    10,127
    2,831
    I use a socket that is 1-1/4", and is a 6 point kind, not the 12 point kind. It also has a 3/4"" square drive instead of a 1/2" drive. I use a 3/4" drive sliding T handle tool to turn the socket 9 with a 3 or 4 ft length of 2/1/2" over that. That slider has a blackhawk p.n. 69997 on it.
    I used to use a socket that had a 1/2" drive, and the 1/2" breaker bar snapped off; thus I went to the beefier 3/4" drive.
  5. zzyzzx
    15,187
    1,225
    If, for some reason you don't want to own a 32mm socket, it's a free loaner tool at one of auto parts stores.
    denisond3 likes this.
  6. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,504
    1,167
    Vancouver Island, Canada
    I've broken two 1/2 drive tools on CV joint nuts, so finally bought a 3/4 breaker bar on sale at the tool store. Works great!
    If the car is an automatic, don't put it in park to stop the wheel from turning, as there is tremendous torque and impact when you loosen that stubborn nut, enough to possibly damage the park pawl in the transmission. Having a helper stomp hard on the brake works well, with the wheel on the ground as well.
  7. pextor
    pextor Moderator Staff Member
    5,992
    834
    Lancaster, pa
    Just put the car in reverse and let the engine do the work.
  8. denisond3
    10,127
    2,831
    Alas; with most of the Escorts I have hauled home, they would no longer move in any gear - so going into reverse didnt work for me.
    I will likely do that when I go to replaced the driver's side CV axle - which has split the boot on the birfield-rzeppa joint.
  9. headmn
    headmn FEOA Member
    15
    6
  10. headmn
    headmn FEOA Member
    15
    6
    Thz to all for your inputs. indeed, the 32mm socket does work with 1/2" breaker and 2.5 ft cheater bar. the 32mm with 12 points fits but is sloppy between contact points. it almost seems like the tite proper fit would be 31.5 mm? if I
    can find or run across a 1 1/4" socket i ll give it a try. i have gotten PART of the passenger side CV and axle but will get a pry fork/wedge to get the remainder out of the transaxle case. had lots of trouble trying to use a
    small crowbar. wish me luck with this epic undertaking, since i have to get the shorter driver side CV and axle removed also. thz, headmn
    denisond3 and zzyzzx like this.
  11. denisond3
    10,127
    2,831
    A cold chisel should be able to be stuck into the space between the side of the transaxle and the inner CV casing; and hit sideways with a hammer.
  12. Joey_Twowagons
    2,504
    1,167
    Keep in mind that the aluminum of the transaxle case is not that thick, and don't crack it!
  13. Defunct SR Owner
    Defunct SR Owner FEOA Member
    37
    14
    18
    I had a hell of a time getting off an axle nut on my first SR (don't remeber which side). I then used a large screw driver to stick into the the vent slots of the of the disc rotor and brace it against caliper and I also used a 3/4 drive breaker bar and socket. It turns out the axle and nut were left hand thread. Of course both were destroyed.
    My fellow Team ZX2 enthusiast didn't believe me when I first post this story but I'm a retired machinist and know the remnant of a left hand thread when I see one.
    If this method can tear off the thread then it should be able to remove a rusty one.
