Common causes of poor gas mileage:
Engine:
Dirty or bad MAF Sensor (SOHC).
Lazy O2 sensor (pre cat). Does'nt allways trip the CEL right away.
ECT (Engine Coolent Temp Sensor)
Or poor engine temp - runs too cool, ECU never see's closed loop. (See common problem thread for thermostat housing problem for SOHC)
Under performing ignition system. Time for new plugs and wires.
Internal Engine Problem. Compression check might be in order.
Tranny:
Overdrive torque converter lock up problems.
Rolling Resistance:
Under Inflated Tires.
Poor alignment.
Dragging brakes.
Bad Wheel Bearing.
Junk in the truck.
Engine:
Tranny:
Rolling Resistance:
Poor alignment.
Dragging brakes.
Bad Wheel Bearing.
Junk in the truck.
If I missed any thing feel free to post up and I'll add it.zzyzzx said:The 1991-1996 models are prone to fuel leaks at the filler hose and fuel pump gasket areas. That could easily reduce gas mileage.
