The front of my car goes "klunk klunk klunk" | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by pyro_maniac69, Nov 16, 2006.
  1. pyro_maniac69
    pyro_maniac69 Guest
    749
    93 LX 5 speed 140K miles
    The passenger side front of my car has decided to start klunking, I can feel it in the steering wheel, and it feels like I'm losing control of the car somewhat when its doing it. I turn the wheel to the left it gets worse, turn it to the right, goes away. I've also noticed that it is only doing it when it is raining out. One person said to check my brake pads, another said my CV joint is prolly going bad
    I have new inner tie-rods, outer tie rods, and passenger side balljoint
    Suggestions?
  2. bluefoton
    bluefoton Guest
    223
    err.. unbolted wheel?
  3. pyro_maniac69
    pyro_maniac69 Guest
    749
    checked em, they are good
  4. major
    major New Member
    1,431
    Knoxville, Tenn
    The C.V. joints are GONE if it's got a snapping sound like breaking a pencil over and over.
  5. pyro_maniac69
    pyro_maniac69 Guest
    749
    no, doesn't quite sound like that
    weird thing is, seems to of started happening right after I replaced my balljoint
  6. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    Get the front end up off the ground and push and pull with your hands on the wheels in different directions untill you feel the slop.
  7. pyro_maniac69
    pyro_maniac69 Guest
    749
    and that will tell me?
    is my wheel bearing another possibility?
  8. JohnnyBee
    JohnnyBee Guest
    1,828
    check the bearing, check the bal joint if its defect, check the tierods
  9. SeanClearwater
    SeanClearwater New Member
    100
    My guess is the strut mount. Mine went bad and would clunk when I turned the wheel. On my car the strut mount bearing had a lot of drag, and would cause the strut shart to rotate, (it shouldn't) when the wheels are turned.
    Look at the strut shaft where it pokes throught the strut tower. I'll bet the side that is clunking rotates, while the side that does not stays centered.
  10. pyro_maniac69
    pyro_maniac69 Guest
    749
    would my tire be a possibility? especially since there is a belt broken on it?
  11. coldblooded
    coldblooded FEOA Member
    826
    268
    Austin, TX
    Um. Yeah. If your tire has a big bubble in it, it's going to yank the wheel around. Get it replaced before you have a complete blowout & hurt someone.
  12. pyro_maniac69
    pyro_maniac69 Guest
    749
    well it isn't a real bad break, but I got about a 2"x2" bald spot on one spot on my tire, and everyone has said that its a broken belt
  13. chubyboy
    chubyboy FEOA Member
    651
    5
    268
    Odessa, MN
    u have belted tires?! i would think that everybody uses radials now...
  14. madmatt2024
    madmatt2024 FEOA Member
    9,889
    424
    383
    Upstate N.Y.
    Yah, they are called steel belted radial tires
  15. pyro_maniac69
    pyro_maniac69 Guest
    749
    another update, when there is snow, it doesn't do it either, only with rain......I"m confused
