The 88 EXP super coupe build. | Page 4 | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by austin86, Jul 17, 2019.
  1. austin86
    756
    242
    58
    Ohio
    Before I started this project I got close to 45mpg on the car, mind you this was with a loaded out car with 14" steels and cheap Firestone tires. I don't see 50mpg being out of the question with a less optioned car and better tires.
    ricksgt likes this.
  2. 1982 EXPert
    1982 EXPert FEOA Member
    114
    92
    38
    I get 35mpg mixed driving in my 1.6 4-speed (wide ratio) with late 80s GT wheels so I'm using 195s, it would be much better with 165s but can't buy them locally of affordably anymore for my 13s and I hate the spongy feel of the 13s.
    If you want lower compression you could get a set of CFI pistons (they're flat)
    I'd take them 11:1 domed pistons off your hands :D
    ricksgt likes this.
  3. austin86
    756
    242
    58
    Ohio
    I'm not sure ware the compression is coming form. It could be that the head was milled and block decked. Once I get the motor on the stand Ill take it apart and find out what all was done to it.
    ricksgt likes this.
  4. 1982 EXPert
    114
    92
    38
    Yeah if it was either of those that puts you in a pickle....
    ricksgt and austin86 like this.
  5. austin86
    756
    242
    58
    Ohio
    My thoughts exactly. I don't might going high CR and high revving. But that would be a step back parts wise.
    ricksgt likes this.
  6. austin86
    756
    242
    58
    Ohio
    Slight update. I got the delrim iner control arm and end links bushings installed. I'll be taking off the wheel hub next, I'll clean up the nuckle and paint it and install the new hub/wheel bearing next
    ricksgt and 88ESCORTV6 like this.
  7. austin86
    756
    242
    58
    Ohio
    Ok, dumb me though I could get the hub and nuckle out with only half the suspension installed haha. So I'll have to reinstall the suspension before changing the hub and wheel bearings.
    I was also messing around with the stock efi manafold. It's a two part manafold witch gave me an idea. If I could find a away to plug the fuel injector ports I could make a adapter plate to fit dual Webber 40mm or 45mm carbs. How ever I'm still not sold on any one fuel setup. Dual weber 40mm down draft would look cool. But I still like the idea of the Weber 38 or bike carbs.
    The last photo is the stock 1.9l carb intake on top of the efi intake.
    ricksgt likes this.
  8. austin86
    756
    242
    58
    Ohio
    I was also at storage last night and found a few upper motor mounts so hopefully I can use one to make a poly bushing.
    ricksgt likes this.
  9. austin86
    756
    242
    58
    Ohio
    I also forgot to mention this. I also found a speedo with a little under 5k miles on it in storage. If it works its going into the car.
    ricksgt likes this.
  10. austin86
    756
    242
    58
    Ohio
    I finally found what was holding the dash in place. A few steel clips. It's not setting in the car with some wires still holding it in place.
