I just had the cooling system flushed, and installed a new thermostat, because my temperature gauge needle has started to read higher up the gauge than it has been while driving around town. (slightly above the "R" in NORMAL). The fan does not kick in until the needle hits to bottom of the "O".
The needle is solid right at the center ("M") during freeway driving.
A laser temp gauge reads the lower radiator hose at 186°F; a totally acceptable operating temp. As long as I know that the actual temperature is only 186°F, even though the gauge reads "hot (er)", I'm good. The needle never leaves the "NORMAL" range, so technically it isn't "hot".
So, my question is, where does your temp gauge needle usually point under "normal" operation?
I just ran a search for "temperature gauge" on the 1st gen group and didn't come up with any thing on this subject.
