tachometer not working/electrical | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by wkirk08, Dec 22, 2012.
  1. wkirk08
    wkirk08 New Member
    14
    Just like the title says, my tachometer isn't working. In fact, it hasn't worked since I bought the car (the needle doesn't move.) It didn't bother me then, but now that I've put some hard earned money and time into it, i'd like it to be functioning properly. Is this something that's easy to fix, or do i have to take apart my dashboard? Also, on my shifter (automatic) , the gear selections (P , R, N, OD,D, L) do not light up at night. Same with the controls for my heating and air conditioning, they only seem to want to light up after i turn them off and on a couple times.
    Is this all fuses, or some loose wires somewhere...or both? Thanks in advance. And Happy Holidays!
  2. pextor
    pextor Moderator Staff Member
    5,932
    791
    Lancaster, pa
    my tach is finicky too, I have to smack the dash for it to come back on.
    the light bulb in the shifter needs to be replaced. easy to do.
    as for the heater controls - do you have a factory stereo or aftermarket?
  3. PKII
    PKII FEOA Member
    154
    168
    Mine don't work either. I'm waiting till the speedometer goes out before I take the dash off.
  4. wkirk08
    wkirk08 New Member
    14
    Pextor, i've got an aftermarket stereo. And I wasn't the one who hooked it up. Judging by the way they ran the sub wires and have everything hooked up, it looks like they knew what they were doing. Like I said, the heater controls light up maybe 3/4 time, so i don't know what the deal is.
    Thanks for the info on the shifter light, seems easy enough. Now it's just a matter of finding the right bulb online
  5. pextor
    5,932
    791
    Lancaster, pa
    should be a 194 bulb.
  6. lilnate
    lilnate New Member
    4
    tach is likely the printed circuit on the back of the gauge cluster forming corrosion, easy to remove, easy to clean, but not a garaunteed fix. could be a bad gauge sensor or wire(s) shifter bulb is a 194 as pextor said, and the lighting on the aftermarket stereo face is another printed circuit, but as simple as hooking a pos and neg connection, you can hook it into your cig lighter, it will only have power when the key is turned to acc/on positions, works out 4/4 times
