1 - 12 of 12 Posts
i have a 91 escort, i bought a sunpro tach and well i dont know which wire is the tach signal wire, can anyone help me with this, it would be greatly appreciated. i looked in the haynes manual and didnt find anything useful. i got the light, power and ground hooked up, i just dont know which wire is the tach signal
Discussion Starter · #10 ·
i got a haynes manual, found the tachometer, but there were 3 different wires, tried em all, 2 of em when i connected the tach wire the needle jumped at that was it, didnt do anything. i looked at the wiring diagrams some more but couldnt find anything else for it, so now im stuck unless someone has put one in and knows what wire it is, thanks to you all for the help so far
don't look at where ford hooked their tach up, cuz christ knows what the hell they were doing.. find the part of the book that shows you how to install your coil, see which wire they say is the negative (or the ground) for the coil, and splice it to that.
Discussion Starter · #12 ·
i have coil packs i dont have a distributor, if i did then this would be so much eaiser to do, but ford has to have those damn coil packs in their vehicles, so i dunno what to do next, any suggestions, anyone here hook up a tach on a coil pack ignition system, the engine i have is a 1.9 SEFI
1 - 12 of 12 Posts
