okay guys, I´ve got a 1991 escort GT and my tach isn´t working. The thing is, it works SOMETIMES... usually it wont work, but every once in a while when I´m driving, it will kick back in.
Okay, I don´t know exactly how everything is hooked up, but I´ve pretty much torn down half of my dash and console and pulled apart a good portion of the right side of the engine bay looking for the problem and found nothing.
Here´s what I have done thus far:
1.Checked the diagnostic module for any corrosion. Checked out AOK.
2.Checked the ignition coil for damage/corrosion- checked out AOK.
3.Checked the ignition module for corrosion/damage- looks fine from the outside, but I´m suspicious about whether or not it´s working. I don´t know exactly what its function is.
4.Checked out tach cluster. Checked out AOK with no corrosion and all connection points clean and contacted.
5.Checked out ECU- NOT SURE. Looks fine from the outside, but I most of the time the "check engine" idiot light is on in my cluster, and I have a feeling that this is the reason why my tach may not be working, because my EDU is about to shit the bed.
Here is a diagram of the ignition system and tachometer:
CAN SOMEBODY EXPLAIN EXACTLY HOW THE TACH WORKS AND WHAT YOU THINK WENT WRONG??
This baffles me because all the parts and wires appear to be in-tact and with no rust or corrosion. I think the ECU went bad, but from the diagram, it seems like the ECU may have nothing to do wit the tach.
ANY HELP IS GREATLY APPRECIATED. thanks in advance.
